My Buddy Dave's MS260 and an AM vs. OEM Jug Comparison
5:54 PM
Added the slick Canadian Farm Boys V stack elbow kit. Saw picked up 500 rpm. Happily 4 stoking at 16,200-16,300. Was still 4 stroking a little in the 17's.
Did Mike make that??? That is really slick!
5:54 PM
Yes. Mike @Canadian farm boy made the elbows and the choke levers. He's quite a craftsman and put a lot more work into them than shows.
I do believe that they added some umph to this saw. Kinda like a little tunnel ram.
bikemike
4:54 PM
Cottage grove mn
Good eye.
Cedar and I believe 10". Closest think to pine I have down. I find its only a tick faster to cut than hardwood because it loads up the chain more, you wouldn't think that but it's true-especially with picco.
Chain is picco, square filed by Mike (Canadian Farm Boy).
Time for some cottonwood for that Lil chip ripper
RI Chevy
5:54 PM
earth
I believe 026's and early 260's were 44mm.
Not sure exactly when they went to 44.7mm.
Wonkydonkey
Plastic member
10:54 PM
Sussex, UK.
Yep, I've got a ms260, it had a/some 44mm p&c then I got a 44.7. I put it on and took it off. It did not run right, I had no clue what I did wrong so I put the old 44 back on, and now I'm keen to have a go porting this 44.7 f-tec thing and setting the squish etc...:clap2:
So this is the sort of thread I needed to help me.
Cheers to Drf256 :drink:
bikemike
4:54 PM
Cottage grove mn
I had a 260 come in with a *f-word tec jug on it. No rpm no power no pick up put oem jug on. Mm and vroom off it went
5:54 PM
You'd be correct Jeff.
I'm not sure on the year it changed. I was told that they went to 44.7 because of EPA rules choking down power. The increased displacement was supposed to balance that out.
The 44.7 saws say 50cc and not 49cc on the tank label. They also have a small heat shield between the jug and the exhaust gasket that the 44mm lacked.
Basher
6:54 PM
Canada
Sometime shortly after 2002, best as I can tell from reading tech bulletins from Media Cat but no serial number cutoff .
RI Chevy
5:54 PM
earth
Cool. Thanks for the update.
MattG
Chainosaurus Rex
10:54 PM
Cambridgeshire, England
