Ms 180 help/ question
Welderman85
3:48 AM
Michigan
Hello all i ended up with a little ms180c last year. I swapped a ms 250 walbro 325 carb on to it for adjustment and it runs great. My problem is after it sits for a few weeks you have to pull on it 10 times or so to get it to fire. Is that a tuning issue or could it be because there's now prime on this saw. Thank you
Sloughfoot
12:48 AM
Norcal
Also, if the plastic cover isn't on just right it'll interfere with the setting and keep it from choking.
Some of them take a few tries to get them on right.
Brad Button
12:48 AM
Angels Camp,Ca.
I have worked on way too many 180s and have owned at least a half dozen, and they all take around 8 to 10 pulls to get running if they have sat a while. It is just the way they are. Once they have been started, they will fire right up with just a few pulls.
Sloughfoot
12:48 AM
Norcal
Truth. Mine takes at least 5 to 10 every time when it's sat, but it always starts. Around 5 full choke then 2 or 3 half choke is the usual.
