MS460 compression
Fruecrue
certified hand catcher
2:02 AM
Alden NY
0F860D26-A262-46C3-A9A5-AD0DF4EF19D5.jpeg I have an Ms460, bought it from a friend's uncle, he had a farm and 80 acres, this was his firewood saw.
Stock as far as I know.
182 psi.
Saw is strong, was going to tear it down and port it, but now I’m pondering it.
What say you? Is this normal for a stock saw? Should’ve measured squish as well... but didn’t.
Fruecrue
2:02 AM
Alden NY
I’ll find out tomorrow. Al knows his saws, I’d better pull the jug to be sure.
I put a dual port muffler on it a couple years ago and could have cleaned the exhaust port.....
Hard to remember.
:nusenuse:
Fruecrue
2:02 AM
Alden NY
It looks like a pretty thick crust of carbon has already been scraped off the inside of the exhaust port. You can tell by all the scrape marks and little chunks that remain.
Well, there’s been a motion and a second.
Would be foolish not to follow up.
2:02 AM
I was gonna say, my 046 was 175 PSI stock, so it may not be that unusual.
If it runs good, I would leave it as be.
Most of the time you can not delete the base gasket on a 460 w/o cutting the squish. Which is very different than most 044/440s.
2:02 AM
Hard to remember.
:nusenuse:
See what you can view not pulling it apart.
Jim is certainly correct in his assessment, but so are Brad and Mike. They are typically higher than the 155 that’s usual in other saws. Is only take a .010 to .020 band cut to ouch them into the 200 psi range.
JonCraig
1:02 AM
Tennessee
I don't have a compression gauge, but I have two 1128's. One is stock, the other has a gasket delete. The stock one (obviously) works just like normal. The other I did a gasket delete and it has .022 squish. That small bump (from ~.034 IIRC) added enough compression that the saw will pop up the decompression valve on its own, every pull.
If yours doesn't pop up the decomp valve, I'd suspect (like others in the thread have said) that it's just how it came from the factory. My $0.02
Fruecrue
2:02 AM
Alden NY
Pulled the jug, good amount of carbon.
Round chamber, mahle.
Squish was .029”
Base gasket is .020”
Need to clean the chamber.
Intake and exhaust ports are good and wide.
I didn’t time it. Piston looks excellent other than some carbon.
The plan at this time is to get the squish around .016”-.018”, whether I sand a bit out of the chamber or find a suitable gasket is yet to be determined.
I will also advance the timing.
