mtnwkr
- 7:03 PM
- Jul 10, 2016
- washington
I responded to an add on Offerup and picked up this ms441 for dirt cheap. The guy's story was that he got it with the bad P&C, started tearing it down and lost interest.
Piston is definitely bad, cylinder might be savable, I'll get a picture for you all to be the judge of.
I've never torn a saw down this far and this one looks a lot more complicated than the older saws I've worked on. The only thing I've found missing so far is the handle for the pull starter. When the compression went the original owner must have pulled the rope till it broke trying to start it..
I assume it'd be best to replace the crank seals? Never done that but I learn quick. All the rubber parts I've inspected look good.
It has the M-tronic carb, I've never dealt with one of those.. Shouldn't it have stopped the saw from burning up?
If I put the saw together again, do I have to take it to the dealer to get it tuned? I'm still on the fence about building this or parting it out. It looks in pretty good shape under the oily mess.
So, Piston and rings, possibly cylinder and crank seals. Anything else I should replace while I'm in there?
