Terry Syd
- 6:30 PM
- Jan 18, 2016
- Comboyne, NSW Australia
OK, I mentioned early on that I would post my Walbro HD-5 carb mods when I got it dialed in. Here's what I ended up with-
First, push out the main discharge nozzle and block off the inlet to the low speed circuit with a bit of GB Weld. Clean it up and put the nozzle back in. (This separates the two circuits and allows the low speed circuit to flow better)
Drill a 1mm hole in the wet side just before the low speed needle seat to allow flow through the low speed needle.
Drill out the auxiliary jet to .35mm
Pull the welch plug and drill each of the air bleed holes one size larger. Replace welch plug.
I used a slightly weaker metering spring to bring in the fuel a bit quicker (better throttle response).
The engine likes to cut around 11,400, but you can pull it down to where it won't bog, but the clutch will start to slip (indicative of a broad, flat torque curve that doesn't drop off the curve). - You can start the saw in the cut, bar buried in Ozzie hardwood using a 20" NK bar with an 8-pin and a full 6 degrees of cutting angle on the chain - in other words it has torque off the bottom.
