Jscb1b
Mister Slapnut
- 10:25 PM
- Jun 22, 2023
- AZ, USA
I have 3 ms250 that need help. One has a meteor piston and cylinder. The rings are stuck in the groves. The piston is not scored that I can see. Is it worth getting a set of caber rings and cleaning up the piston or getting a piston kit? The second one has a leak at the clam shell. What sealant is recommended? The third needs a new flywheel. OEM or aftermarket? What brand of aftermarket is recommended? The two that are getting split need new seals. Again OEM or aftermarket and what brand? Thanks!
