- 7:59 PM
- Jan 14, 2016
- North western Ohio
Just some point of clarification,not that it means anything .If you are say bucking firewood logs,a lot of them you might run a saw an entire tank full of fuel before you shut it down, .Generally speaking that would be between 30 and 40 minutes depending on the saw and how much over stock it was .
If however you had a saw in a tree it would never see a continued long run like that .It might be in use for 6-8,rarely 10 hours but it would not be running all that time .I'd hate to guess how though in the course of a work day how many times a 200T goes from idle to wide open throttle or how many times it goes from dead start to run .These are not normal chainsaws by design .This is a sprinter,fast quick cuts .Not that it won't hang for the long haul because it will but that wasn't what it was designed for .
Now because it is a thoroughbred you have to stay on top of things if you want it to last .If that takes a set of bearings and seals or just seals don't dilly dally with it ,get-er-done .
