tomscott
- 5:44 PM
- Jun 4, 2016
- Northern Maryland
Yes, it's just an MS180, just a plastic fantastic trim saw, but we all wonder if we can get "more". There is an insert that goes in the intake throat that can only restrict air flow. Maybe it helps control spitback, I can't think of any other purpose. Just wondering if anyone else has results of removing. Currently with the the spark screen removed and the muffler louvers opened up slightly it will still four stroke occasionally out of the wood. With it running so well with the existing fixed jet carb, I'm not really anxious to make a mod that will require getting an adjustable carb.
First pic is with restrictor next to throat:
And installed:
And finally a close up showing just how restrictive this thing is:
If the best answer is "just leave it alone", that's fine, it carries its weight in the line-up just fine. I'm actually kind of impressed by it when I cut a larger log, usually happens just because it is the saw in my hand at the time, and it is good to run it hard every now and again.
And installed:
