MS 660 w cross fire failure
Lowbudgetwhiteboy
OPE Member
12:33 AM
California
Here is that exact piston and cylinder kit. I have it on my motorized bike. I had to modify the cases quite a lot but here it is, has about 100 running hours on it and still has to much compression to start without the decompression valve.
Life got in the way and it got rained on a few times so not pretty anymore.
Moparmyway
Its just a saw
12:33 AM
In a meeting
The 29$ no name China bearings and seal kit and the crappy top end you sent pictures of. Both would be a waste of time and money
Hence the screen name he chose.
I don’t see mr low lasting too long here, my BS meter has been ringing loudly with this one. Hopefully I’m wrong
Lowbudgetwhiteboy
OPE Member
12:33 AM
California
Seriously don’t waste your money on the oem stuff. Because no matter what parts you get. If you don’t know how to put it together and run it. You won’t have a chance.
Moparmyway
Its just a saw
12:33 AM
In a meeting
You now believe that the OP doesn’t know how or didn’t put it together correctly ?
12:33 AM
@dall you're not the only welder in the house.
12:33 AM
Teach me
I'm here to learn.
Lowbudgetwhiteboy
OPE Member
12:33 AM
California
I am making a point about if you don’t know what you are doing you can easily make oem parts “complete junk”.
Lowbudgetwhiteboy
OPE Member
12:33 AM
California
I get it your bored since you’ve been on lock down and figured you’d troll a bit. Glad you know what your doing might as well quit wasting your time here.
I am an investor and do most of my work from home but good one[emoji1303]
Definitely use that one more!
