429p
Active OPE Member
- 5:03 AM
- Mar 20, 2020
- Central Texas
I have assembled an Farmertec MS 361 kit, first time for me.
The engine will not start. I might get a "burp" at first with the choke on, then nothing with the choke on or off. I waited a couple of hours, and then i do not even get a burp after trying to start again.
Spark plug is not wet. I do have a spark at the spark plug. I cranked the engine with spark plug out of the cylinder, and I see a spark.
1. I have tested the fuel tank. The tank holds pressure, and it does not hold a vacuum. I think this means the vent is working.
2. I pressure tested the carb through the input fuel line, and it holds pressure.
3. I blocked off the carb and the muffler port for the pressure test of the case, seals, and cylinder. I pulled a vacuum, and did the pressure test through the impulse line. Vacuum and pressure test shows good. I used the Farmer tec case assembly tool to join the case halves. The seals do not look prolapsed. i did replace the decomp valve with a Stihl decomp valve. Farmer Tec valved leaked.
4. i put a NKG spark plug on the cylinder.
I am going to go back and do another vacuum and pressure test.
I suspect that the impulse line is not pulling a vacuum or pressurizing the carb. Is there anyway to test this?
I could pour some fuel into the top of the cylinder to see if that will get it to start. I have tried this once, but i will try it again.
thanks in advance
thanks in advance
