J.w Younger
1,000th Member!
- 2:11 PM
- Mar 28, 2016
- arkansas
MS241 wont idle, stalls a lot. Any thoughts?
I'm finding one for the 261 but so far no luck on the 241, do you know if they are the same?Solenoid and filter kit seems like a good first step.
Here is what the part number is in the 2021 IPL:I'm finding one for the 261 but so far no luck on the 241, do you know if they are the same?
Here is an on-line IPL for the 241, you can use it to get part numbers if you need to look up others in the future.I'm finding one for the 261 but so far no luck on the 241, do you know if they are the same?
didn’t recall a non mtronic 241I turned the idle stop screw about an 1/8 and it hasn't stalled one time in 3 tanks.
Must be typo and he means 251?Not on a 241.
Not on a 241.
Thanks, if it starts acting up again I'll replace the solenoid and filter.Where’s the idle adjust since mtronic is self adjusting mixture and idle. Your saw needs a green solenoid if and when it needs one. The old reset of start in triangle idle for 45-90 seconds and shut off without touching throttle. The black solenoid was all plastic and seat would wear out so it couldn’t adjust properly. The green replacement has metal seat like the white one and this was also the reason for the orange filter that is twice as fine.
