Modifying Oil Pumps
11:23 PM
660 uses the same pump too, I believe that info should apply to it as well. Imo the stock 460 oiler is perfect for the 361, it uses one tank of gas per tank of oil used. The R oiler would be too much for the 361, you would be running out of oil well before the gas. The R oiler is nice on the 441/460/461.
Junkwrencher
10:23 PM
Tennessee
All 1128 series oilers are rated at 5cc per min. at the lowest setting. The 660 oiler 1122 series is very different from the 1128 series.
