MMWS 10mm 044
Roadfxr
5:04 PM
Iowa
How's my old red light?
It's still chewing up everything that's thrown in front of it at a very high rate of speed. I actually think I saw it smile the other day after it got done destroying a huge cottonwood log.
jmssaws
Banneded
5:04 PM
That was one of my favorite saws.
I'm glad to hear that
David Young
Safety First !!!!!!
6:04 PM
vt
Mastermind,
I think you should label this renaissance of builds as "I learned so much I forgot what I knew."
They are all sounding great and seem to be carrying some good rpm.
I agree on the tune. Normally I'll get it close by ear and then make some cuts in 8 inch wood or so. Tweak it back and forth you can find that spot. If its lean she ll fall on her face. I go just an rch rich from as fast as it will go.
later
david
5:04 PM
Mastermind,
later
david
It's amazing what happens when you finally get certain models really hauling ass. In my case, I kept looking for more, and probably went backward a little. The more you tweak the numbers to make max power, the tougher the saws get to tune just right. I can get more......but not without carb tweaks and stuff that is outside the realm of a real work saw. I'm thinking that this 044 can give us a wee bit more by adding a recoil side deflector, and ditching the dual port cover. Much more? I doubt it.
jmssaws
Banneded
5:04 PM
When you start getting tuning problems I found its on both ends,get one close to max and the muffler and carb both get real picky.
Muffler is what caused my carb tuning trouble.
Deets066
AKA Deetsey
6:04 PM
Tri port, FTR
5:04 PM
Ouch! That had to hurt Randy...
I'm used to it Dan. These guys are ruthless. If they ain't insulting my perfect legs, they are talking crap about my flawless saws. I get it.......they're just jealous.
:applaudit:
Brewz
10:04 AM
Hunter Valley - Australia
I have found my 066 to be picky on the tune now that I have ported it.
The muffler has 3 large openings. I am thinking of making a blanking plate to seal off the front cover opening and see what that does.
jmssaws
Banneded
5:04 PM
A ported saw will hunt some and the farther you go the more it needs to be tuned.
Muffler opening is a lot of it.
Roadfxr
5:04 PM
Iowa
Not the best picture but the 044 performed flawlessly cleaning up storm damage. My cousin had never run or been around ported saws. I think he's hooked! Thanks again @Mastermind
jmssaws
Banneded
5:04 PM
Taking care of my precious?
Roadfxr
5:04 PM
Iowa
Yes I am. Came home last weekend after several weeks on road. First thing I noticed was beloved was not sitting on the bench in its normal spot. Found it on the floor, wife had moved it but had put a rubber mat under it so it wasn't sitting on the concrete. Whadya know she does listen once in a while. Lol!
