Mikuni Carb
Kevin
OPE Member
3:23 AM
northern Ontario
I have a Mikuni carb made in Japan from a Kawasaki 5hp engine and I would like to identify it.
Anyone familiar with this model?
Thanks.
Shanks
Happy little lumberjack
3:23 AM
Beaver Falls pa
I would try the ipl at Jacks small engine. They have the kawasaki ipl
Kevin
OPE Member
3:23 AM
northern Ontario
Sears shows the ipl for this discontinued model but don't list the model of carb.
super3
3:23 AM
Indiana
Except for the choke arm that is the same model (#715670) used on some Briggs Vanguard.
I just went thru one for a friends generator.
Kevin
OPE Member
3:23 AM
northern Ontario
The carb I have is definitely Mikuni and is different from the Briggs but may fit.
I cleaned the Mikuni and reinstalled it but wanted to find the model number so I could order parts for it on-line.
The run cap is also cooked and they don't make that any longer so I have to install another larger capacitor outside the generator.
super3
3:23 AM
Indiana
The model # is on the outer mounting flange but,it is poorly stenciled on and rubs of easily.
Yup, Mikuni on the vanguard I repaired also.
Like I said, different choke arm configuration.
I doubt they made that carb just for Kawasaki.
Several applications use the same basic carb body.
I found no gasket "kit". Have to purchase the bowl to get gaskets. Needle and jets were available separately.
Kevin
OPE Member
3:23 AM
northern Ontario
Any idea what this small hole is for ?
Should it be left open in the gasket or can it be covered over?
Kevin
OPE Member
3:23 AM
northern Ontario
The mating part is the intake manifold, the gasket kit doesn't show a hole in the gasket but I'm wondering if the cut out is large enough to include the hole in the carb?
P.M.P.
Stiff Member
3:23 AM
Michigan
Hopefully you got the right gasket.If gasket does cover it you could always drill hole out of gasket.
Kevin
OPE Member
3:23 AM
northern Ontario
The original gasket is long gone so I had to make one, that's why I can't remember if the original gasket compensated for the hole in the carb.
P.M.P.
Stiff Member
3:23 AM
Michigan
I would leave a small hole in gasket if it were me.
