Measure to get timing numbers?
Ronie
6:53 AM
NC
Can someone explain or point me to a thread on how to measure with a ruler to get the timing numbers?
cuinrearview
Handy dood
6:53 AM
Dowling, MI
I found a page that had some Stihl con-road lengths but I can't remember where. A mm or two doesnt change the heights much at all relatively speaking in these small engines. I am ball-parking the rod length until I have concrete info.
Ronie
6:53 AM
NC
I'd like to get an accurate transfer timing number on a Poulan 31, They are hard to see with the domed piston and it has a cut out at the transfers. I'm not planning on changing the timing, I'd just like to know what it is.
Ronie
6:53 AM
NC
Thanks Tim, I just tried eye balling it and I'm only 1.5 degrees off of what I was guesstimating.
Pincher
5:53 AM
sw corner of twin cities mn
Since you have a degree wheel, measure your piston travel from tdc to 90 degrees. Use that measurement and change rod length until it matches the results from the calculator. Should get you really close.
David Young
Safety First !!!!!!
6:53 AM
vt
I had a thread on this let me see if I can find it...
David Young
Safety First !!!!!!
6:53 AM
vt
Like you said. Conrod Length does not typical have a huge impact on numbers. So I just take an educated guess with calipers
