McCulloch CP 125 build
Brush Ape
Direct Connection
4:28 AM
Metropolis, Il
This is about the point where someone tells a story how...
Well I was driving a 454 powered 1974 Cheyenne 3/4 ton on a roadtrip in a hell of a rainstorm about 25 years ago. Well the carrier bearing let go the one that supports the driveshaft about halfway on those old pickups. Man it was sketchy that far from home raining like that but at least it was June. I had a partial quart of 30 weight I ran in my push mower and a sock that I had wiped my ass with in the back of the truck. So I oiled the heck outta that sock and stuffed it in the carrier housing around the driveshaft with a stick. Got back to town and then some 'cause it was a Saturday evening and I couldn't get a new part for a few days. Once I was at the house I went ahead and shot in some goo with a grease gun and she was smooth as silk and probably would have worked for a long time. Many other stories about 'ol Cheyenne I will probably tell you guys someday.
Redfin
Meh...
5:28 AM
Central Pa
Man Keith, you must have some wicked movements.
smokey7
5:28 AM
Detroit
It will work well if used properly. In a spun bearing it will work great if the hole is pretty round. Now if its ovaled out you would want to have the other side assembled in a standard mag cased saw. Then slide the other prepped side on. If its clean and the bore is reasonably round you will be golden with this stuff. I feel its strength is way stronger then jb weld. Ive tried jb it didnt work anywhere near as well.
Mkinslow
4:28 AM
Tennessee
The one I have is still round. I can just barely push a bearing in and back out by hand. I may try this after I find a crank. Thanks
Chainsaw Jim
Con Artist LLC
2:28 AM
Springfield Oregon
If it isn't wobbling in place then first bond the bearing in the case half by itself so you're sure it is seated properly. Mating the case halves together while seating with the loctite will make it a challenge when it tries to set up on you before you get it all the way in place.
Mkinslow
4:28 AM
Tennessee
Yes sir! Got it
p61 western
Ol Mudflap
2:28 AM
GFY
How long is the work time with this stuff?
smokey7
5:28 AM
Detroit
If you have a small gap .005 or less you get maybe 5 seconds if you use the primer activator. Maybe 10-15 seconds without. If the hole is egg shaped put bearing on crank first. If the hole is straight and very little slop get it in the hole first. You can get the case cold first that will slow the cure process to gain some working time.
