Warped5
- 8:32 PM
- Jan 7, 2016
- Northwest IN
TJ, sent you a PM ...
Now this piston business has got me interested in thinking about reviving the 850 I have residing in a box in my shed .I happened to find several used piston but noticed a new aftermarket sold by I think little red barn .It's listed as a B size by part number ,doesn't have the bearings which really aren't a problem to find .I wonder if it's worth the effort to try it out .
From what I understand the pin is a press fit in the rod which I suppose would take some heat on the pin end of the rod and a press of some sort or a pull bolt contraption . It would make sense the needle bearing cages would also be some kind of a press fit .Uncharted territory .I've never had a rod off a ten series piston assembly or any McCulloch for that matter .
One of my co workers said they used to run 42's on them....must have only been in soft wood. I'll probably end up with 36" Oregon light bar or something other.I think 42" is overly optimistic, 36" seems max to me and mine wear and are happy with their 32" bars. I just ran them both in a piece of old growth fir last weekend. 850's are smooooth (895's are definitely not) for sure. Mac sure had rubber AV down well, better than Stihl IMHO.
Lowest temps here currently have been +55 lolWhen I put mine back together I just left the piston outside for a while. It was -14*F at the time.
