Mastermoobs Christmas Build
Red97
11:29 AM
MI
Does anyone wory about it only havin a single ring? My stihl dealer here uses that against them when someone asks about a Dolmar.
Less friction/heat.
The don't imagine the longevity is much of a factor. Guess the way I see it, by the time a dual ring piston is wore out the jug isn't far behind. Where the single ring jug can go again lol
11:29 AM
I find no issue with a single ring at all. I know Brad uses a single ring in many of his Stihl builds.
The single ring saws I've played with had a thicker single ring than the double ring saws. For instance, the 262xp is 48x1.5mm. The 036 is 48x1.2mm.
As long as the rings look ok, I prefer a loose used lower ring and a new top caber. Best of both worlds.
Looking really good Moobs.
Redfin
Meh...
11:29 AM
Central Pa
10:29 AM
What do you suppose is the reason for the tube? Air gap to keep heat away from cylinder?
It continues on into the muffler a little way, then turns down. I'm not sure what they were thinking, but I figure it has more to do with eliminating hydrocarbons somehow than heat.
10:29 AM
Is there going to be a thread on the tractor ? I like tractors.
It's a JD 1120. It's got a case of rusty fuel tank. One of the injectors got some trash under the pintle, leaked some fuel into the cylinder and hydro-locked the engine.
Once I was able to get it running again I changed the fuel filters, and ran a few gallons of fuel with Seafoam in it to clean up the injectors. Then I changed the oil and filter, and worked on the intake heater.
I'm just glad to get it back in service without too much drama.
10:29 AM
randy i had a rusty fuel tank on my 73 cub loboy 154 and fought it for a while until i washed it out with water then put the plasma cutter to the tank and sanded inside the tank no more problems
I might just buy a new tank. They ain't crazy expensive. I've been using this tractor for a year and a half at least, I didn't notice the sediments in the bowl till I was changing the filters. Some yahoo painted the bowl. I'll be watching it now.
11:29 AM
plasma cutter was funner lol
