Makita Dealers?
7:55 AM
I need a case gasket, base gasket, a set of seals, and a new style piston kit.
- 038 111 043 Case gasket
- 346873-0 Cylinder base gasket
- 962 900 062 crank shaft seal, clutch side
- 213814-0 crank shaft seal, flywheel side, 15x24x7
- 038 132 070 piston kit (I can not confirm whether old or new, but I am assuming new style)
Everything is listed in stock in Germany.
7:55 AM
@166 Steve, unless You are on bad terms with him.
Gotta call him though, to my understanding he doesn't log in anymore.
7:55 AM
I am not sure the best place to get it and they won't be dolmar own but I know there is a Stihl seal for the flywheel side and a Husqvarna seal for clutch side with the same dimensions
If it is not a secret I for one would like to know part numbers to those. :)
