TX_Welder
- 8:52 PM
- Oct 22, 2019
- SE Texas
I've got an old echo 660-evl that I think has spun crank bearings. It had bad crank seals and was running bad and I corrected that issue but when I got it fired back up it would man an odd noise on deceleration.
So, I pulled it back apart and it appears the bearing have spun in the case. You can slide the crank side to side a little but I can feel no up and down play. I'm sure it has some but you can't feel it.
Is there an epoxy or sleeve cement that I could glue the bearings in with or is it just shot ? We used some cylinder sleeve cement from john deere to glue some valve guides back in a lawnmower head. Four years running still going strong.
Saw isn't in that bad of shape, shows 150psi with something like .060" squish. I hate to just scrap it. My dad fed us with that saw around the time I was born in 87. I'll post a pic of it later.
