- 12:54 AM
- Apr 28, 2016
- Croatia
I don't want to step on Your toes, nor is this post intended as criticism! :surrender:
I am a homeowner firewood hack, and I have a couple of these saws with three different spike versions.
The US Style 1 that You have on Your Makita generates good leverage and makes it easy to force cuts, the US Style 2 even more so.
Is it possible that You force Your cuts causing heat and pressure to the rails and generally wedging Your bar apart?
From my viewpoint that bar has seen a lot of use, or some abuse - there is almost no paint left on the PH side.
It also looks like You haven't flipped the bar for equal wear?
Factory original 12 years old Dolmar branded Oregon laminate bar.Damn. Paint isn’t even worn off
To be fair this picture was taken mid summer last year so that makes it only 11 years of usage - note the amount of paint still intact on the PH side.
I admit it is not a high tech light weight bar, but I think it kinda shows "non abuse".
I tend to utilize my saws spikes to finish a job at hand too, but I prefer not to do so throughout an extended period of time.
Steel sliding over steel under pressure is generating a lot of wear and heat!
Again, no criticism, no bashing, just trying to figure out why the VersaCut doesn't work for You.
