I am in search of a couple of these elbows to replace ones that are cracked and suck air
I am not opposed to trying to rplace them with brass elbows if that is an option. Poor design is an understatement.
AFAIK all those little plastic fittings are the same, both Walbro and Tillotson. We actually stock them under a Tecumseh number (Tecumseh used Tillotson carbs on their little 2-stroke cultivator engines). The Tecumseh number is 640363, not sure about the Tillotson number. https://www.ebay.com/itm/232983935613
Yep after diligent searching and cross referencing this is the route I am gonna go. Thanks for the info....
Plastic is not an option anymore, I hate leaks.
Those metal elbows are good. It’s one of the first parts I pull from an otherwise junk carburetor. Definitely need to keep some around. Good find on eBay!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
