MAF143
- 8:01 AM
- Mar 30, 2021
- North Central Ohio
Friend of a friend dropped off a MS391 for me to look at. It actually started but wouldn't tune at all. I pulled the clutch cover off and the PTO side bearing is no good. I tore it down and the plating in the cylinder is torn off in strips below the strato ports. It's like the skirt of the piston was digging into the plating there at TDC. I ran a flapper in there and got rid of what little aluminum xfer was in there. Then I stuck a new piston in to see if it would hang on the rough area in there. It was totally smooth in the bore and didn't hang at all and was not sloppy and fit well. I did ease the bottom edge of the strato ports with some shaped diamond files cause that edge was like a razor. I'm not sure if easing the edges on the piston would also help it last a little longer.
The original piston is trashed where the plating chips just tore it UP... Chicken or the egg. Did the plastic in the bearing go first and allow the piston to hammer the plating till it bit in from the slop and vibration OR did the plating fail first and the chips destroy the plastic bearing carrier killing the bearing??? Possible debris ingested via the strato port, but I would think that might cause more damage above the strato's??? Rookie here just spit-balling...
I didn't see any plating issues in other areas of the cylinder and above the strato ports everything looks good to go. The saw owner doesn't want to spend the money on a new cylinder (even an aftermarket at $110).
Bottom Line:
Can this be put back together with a new piston, bearings, and seals and be run for a couple years or will it just kill itself shortly after running it? I can try to talk him into spending about 50 bucks over his cap price to get an aftermarket cylinder cause I'd hate to give him a "fixed" saw that won't last. I'll discuss it with him either way cause I always want to be up front with everyone, but I'm just looking for a little advice as to if it would last at all or not cause I'm not experienced with this type of failure. If it was my saw I would probably put it back together and run it till it pukes again to see how long it would last.
Bottom Line:
