Looking for 3/8”LP 7pin small spline rim sprocket
KYsawman
9:59 AM
Gone Fishing
Does it still have that plastic clamp in the intake?
Yes it still does, and it is not leaking, I believe keeping the saw clean and a sharp chain has kept the heat down. I think heat is the main reason that the plastic clamp failed. I have a OEM metal clamp, 350 bearing cup, and 346xp NE cylinder ready when the time comes, but till then I’m just going to let her eat.
8:59 AM
Never a more true statement right there.
Did you see that guy that had a build thread for these saws and was using a crank stuffer off a string trimmer and with a little filing you could have stuffers on these saws?
KYsawman
9:59 AM
Gone Fishing
No I missed that one, it would be nice to try stuffers on these saws,
8:59 AM
ajschainsaws
Axes never run out of Gas
2:59 PM
South west UK
Hey Sondre did you get sorted with a small spline 3/8LP rim I got the
Standard spline sprockets and there smooth running
SOS Ridgerider
Muffler Modded Member
9:59 AM
Central CT
Hi Andrew. Yes, I got it sorted out. Another member here @Johnmn had a Stihl rim that was modified to fit small spline. Works great now.
I think I have a standard spline rim for 3/8LP somewhere as well. Not sure where it came from. Lol
3:59 PM
I'll have to keep You in mind if I ever get to successfully adapt the PowerSharp system to run on my D009 saws! ;)
