Find the Water Hose that fits that handle, and it'll work.
I might have something at work that will fit that handle. I have half a mind to try some heat shrink tubing.
So your sayin I should snag the magII for a hundred at my local shop?
A metal tag with "038 Av" with mag below it would indicate an earlier model .Mag II would be later ."Magnum" in the form of a decal would be towards the last of the run.
As far as the outlets on the muffler,one ,two whatever ,it could be any of the former .Besides that it's just a hole.Easy enough to add .
I've got two.The first has the metal tag,made in Germany .The other which is souped came from Brazil with a double outlet muffler .
Picked this up today. Guy had it listed on facebook. It desperately needs a good cleaning and has a Crack in the top cover but it starts right up and runs like it should. $225 whadya think?
What do ya want for it ?
