rmhayes1954
Fighting with a Bad Boy
- 3:29 PM
- Jul 14, 2022
- Lancaster Ohio (se of Columbus)
Bad Boy zero turn with Kohler KT745-3031. Starts well with temporary choke (about 5 seconds then no choke). Runs strong for 20-30 minutes then starts to fail (both cylinders are dying). Surges briefly with governor movement (about 1 minute) then stalls. When it cools down, it's good for another 30 minutes or so. New spark coils last fall. New fuel pump this month. When surging, I can see there is fuel in the fuel filter (filter is a clear plastic case) so no blockage from the tank to the filter. Added a hose clamp to the vacuum line to the fuel pump. Tried HEET fuel dryer to remove any water in the fuel.
Earlier this year the muffler failed with a big hole in the outer shell. That exposed the fuel pump and carb to hot exhaust gas. Did that do any damage? New muffler ($318!!!) this summer.
Any suggestions? I have a new carb but have not installed yet. New fuel pump is installed but that did not help.
