jug wo base gasket
Racer
11:37 AM
Liverpool UK
Hey guys, i see many people use jug chainsaw wo base gasket for rised compression, but idu - after delete base gasket i must use sealant?
farminkarman
I like the red & black ones
5:37 AM
Neenah Wisconsin
PA Dan
6:37 AM
White Oak PA
I have used 518, Motoseal and Dirko. I will never use 518 again and will stick with the other 2. Kevin used 6 tubes of Motoseal so that would be reason enough for me to choose that one.
Ketchup
Epoxy member
4:37 AM
Colorado
I use 1184 all the time. I’ve had a few saws apart where it seemed to overheat and get brittle but mostly it seals well and is easy to apply. Hylomar Blue may be my future.
Disciple of Monkey's
5:37 AM
I've had Hylomar Blue washout on an ill-fitting base adapter and haven't touched it since, at least for sealing bases anyways. It probably has other better suited uses than that.
farminkarman
5:37 AM
Neenah Wisconsin
I had it fail on two husky 350’s. I have never had a failure with Dirko. Never have tried motoseal or 1184.
nbbt
5:37 AM
5543X, 5644X
Nobody use 1184 anymore? Was there issues with it holding up?
1184 is usually at my tool-bench. It seems to work the same as Yamabond 4 or Hondabond. At least in my slightly experienced opinion.
I haven't compared it to motoseal at least not yet.
I pick up the 1184 because it is available locally, as I usually don't want to wait for a delivery.
