KUDOS Jred 630 flooding issue 'UPDATE'
Huskyslinger
10:56 PM
Wa State
So i have a 630 that the carb has been rebuilt and cleaned. Saw starts and idles but pull throttle wide open and saw starts flooding out. Hs is turned almost all in. Any ideas??? Thank you
Squareground3691
1:56 AM
New England
Metering lever either not correct, or diaphragm not in slot of lever if it has one , check needle to . 🤔, possibly.
Huskyslinger
10:56 PM
Wa State
So lever is good for sure. Did a pop off test and was good. Thought about the diaphram but havent checked for sure yet
Firewood Hoarder
Just a firewood hack
12:56 AM
Wisconsin
Would having the gasket on the wrong side of the diaphragm cause this? Or would the pop-off test prove that it's setup correctly and not affecting the metering lever?
Huskyslinger
10:56 PM
Wa State
No restriction in exhaust, going to tear carb back down and go through it again
Huskyslinger
10:56 PM
Wa State
I believe i might have solved it. I another set of welch plugs in and used some wicking grade loctite. But didnt get to run long
Huskyslinger
10:56 PM
Wa State
So a little update. I should have said i had actually modded a 670 carb to go on this. Which is no biggy except, the carb had a changable jet like one in pic. Not a welch plug like the other style 670 in pic. So digging through my carbs i found a tillitson carb off a stihl?? at least thats what the diaphram plate was stamped with. So in that carb i found a jet that was not drill with jet, it was solid except for it does have a ball in it which acts as a defusser??? Any how the saw can now be adjusted properly with screw. If your wondering why i used this carb, well is because i did a lil port job and this has bigger bore. 20240203_162437.jpg
