Jonsered 630
Foreverred
11:59 AM
Scotch Grove, IA
I'm working on a 630 for a friend.have some questions. It needs the gas line.can you get that anywhere?it's not just a straight.how do you tell if it's a super or just a straight 630?what is all different between the 2?the super has quite a bit more power according to the specs we found.thanks for the help
Sent from my XT1055 using Tapatalk
12:59 PM
Av mounts are the same. A super has a 1 piece ignition. Non super has 2 piece ignition. I have a piston and cylinder for a 630 if you need one
Foreverred
11:59 AM
Scotch Grove, IA
What makes the super have so much more power than the straight 630?
Motorhead
Cantre Member
12:59 PM
Tampa Fla.
The piston and the carburetor are different.The origanal 630 had a 218 tillotson carb and a skirted double ring windowed piston.The supers had a 225 tillotson and a non skirted single ring windowed piston,there were other variations of carburetors,But the 225 works just as well as the others.There were probably other subtle differences,These are the most obvious.
Foreverred
11:59 AM
Scotch Grove, IA
Ok thanks guys.its just a regular 630.it has 2 rings and a 2 piece coil
