SOLD Jonsered 2149
Johnmn
10:49 AM
Minnesota
Here's a 99 built jonsered 2149.
Had the plastic intake clamp, I pulled the cylinder and installed a metal clamp. While the cylinder was off I deleted the base gasket. I also advance the timing because they like it! Muffler is stock non-cat, has a newish 3/8 sprocket and a Wahlbro carb.
Hard to tell in the pictures but it does have some overspray on the top cover and front handle.
Would make a nice firewood saw.
Fired saw up this afternoon started on second pull, idled and rev'd up as it should.
$225 plus shipping friends and family or add 3%
IMG_20191208_153759267.jpg IMG_20191208_153748191.jpg IMG_20191208_140602362.jpg
Johnmn
10:49 AM
Minnesota
Pulled the metal shield off the clutch side to fix the bar oil leak that these always have. To find corrosion! F! This saw hasn't panned out well....
USMC615
Fapper Fi
11:49 AM
Mid-Georgia
Good saws...ought not take long to move this one.
woodfarmer
11:49 AM
Bowmanville, On, Can
I bought the saw used from Canada. I was just making a wild guess that it rode on a truck exposed to road salts and that is why the cases were corroded.
More than likely, they ‘re using a liquid brine which is even more corrosive than salt
