Intersting coil and case in a 064
lwhaples
5:12 AM
Vt
Picked up a 064 at a flea market today.Thought the coil was odd. Cool though,never seen one.064 1.jpg 064 3.jpg 064 2.jpg 064.jpg Bummed about the KS jug though.
lwhaples
5:12 AM
Vt
064 case.jpg 064 case1.jpg Looks to have had some machine work done to the case. You can see the insert is flush on top,but will hang a nail at the bottom.On the outside,that's like a shim.The saw had a smoked lower rod bearing.Not sure I want to use the case.The insert spins.
BuckthornBonnie
5:12 AM
Penn Yan, NY
View attachment 91734 View attachment 91735 Looks to have had some machine work done to the case. You can see the insert is flush on top,but will hang a nail at the bottom.On the outside,that's like a shim.The saw had a smoked lower rod bearing.Not sure I want to use the case.The insert spins.
Case is done.
Luckily you have a few 1122s to build up haha.
Cracker Boy
Fl cracker
5:12 AM
Florida
You can buy new oem case from stihl that has the two hole pin bosses close together and put the updated 1203 flywheel and the standard unlimited coil and transfer everything over the case is about 200 the flywheel is 125 unless you find used
Cracker Boy
Fl cracker
5:12 AM
Florida
23130.jpeg see the case on the right were the coil goes this is the correct case for updated ignition flywheel and coil non limited version your standard stihl coil.
