Intake gasket sealant
P.M.P.
Stiff Member
10:06 AM
Michigan
I got a 357xp working on looking at putting sealant around intake gasket flange.
I have some Hondabond will this work if not what would you recommend.
Thanks
P.M.P.
Stiff Member
10:06 AM
Michigan
Sorry Buddy No experts are here you're SOL? I know Iam not one either
Good Luck Pal
TJ the Chainsaw Mechanic
Old Homelites rule!
7:06 AM
I remember having a husky in the shop that had the plastic clamp on the manifold boot. Clamp Barely tightened the boot around the flange causing an air leak. I ended up using a grey silicon to seal it off. I can't remember the exact name, I'll check when I head in tomorrow.
P.M.P.
Stiff Member
10:06 AM
Michigan
Ive seen guys using a red loctite cant remember if its 508 or 518. Was thinking could use hondabond but wasn't sure.
