Terry Syd
- 4:30 PM
- Jan 18, 2016
- Comboyne, NSW Australia
Yeah, drill the air bleed/transition hole and you won't have any further idle issues.
I suggest grinding the jaws of the nippers down until they come in flat on the jet. A lot of the nippers have an edge on them where the 'bottom' of the edge is ground at an angle. Get them FLAT and then put the notch in the edge on both sides. Then all you have to do is get the jet turning before you start to pull it out (the movement is like you are 'unscrewing' the jet).
