Stihlbro
- 10:28 PM
- Dec 29, 2015
- Virginia
I checked the pop off pressure on my Bing carb. It pops at 16-17 psi.
Just for comparison I also checked 2 Zama C3A carbs. The one Zama pops at 25 psi and the other is 30+psi( my gauge only goes to 30)
The 2 Zama carbs have different looking wet sides. I'll post a couple pictures in a minute
If it were me, I would put a stiffer spring in the Bing and retry. It should make it behave better at idle.
I, would also try the first carb you posted picture of, it looks to have independent fuel circuits. When running, I would open the low side adjustment up and see how much fuel the circuit can deliever. In other words see if the low side delivers fuel at wot.
The carb I posted picture of, does not feed fuel to the low side circuit from the main nozzle. The low side is fed from the fixed jet. The fixed jet supplies fuel to the under the Welch plug. I would drill the divot that is inline with the low needle and give it a try. This would make fuel more availability for tuning. Clean up then Venturi (oversize some), clean up the throttle blade and screw for flow.
Other than that, unless you lived closer, I'd say swing on by the house and I could help more. We could cut down the neighbors tree for testing. (Hahahahaha)
