Terry Syd
- 10:51 AM
- Jan 18, 2016
- Comboyne, NSW Australia
You mentioned a difference in pop off pressure. POP is something that became popular from the karting forums, but is really overrated. You tune by performance, not something like POP or maximum RPM.
If you pull the metering springs from the early carb (no plugged circuit) and a later EPA carb, it sounds like they will be different springs based upon you observed POP (25 vs 30+). If they are different, you can try the 30+ spring in the early carb to see the difference.
I'd try running the early carb, trying both springs to see which gives you the best powerband - and then compare it to the Bing.
If it is on a par with the Bing, then the guys that have been following this discussion may want to mod their EPA carbs.
