HELP! I'm stumped...
jacktheripper
Papa Squat
8:12 AM
Wyoming
Oil. Then once you get it going, run the pizz out of it to try and get the rings to set in a little bit.
Like Steve said. I think that my issue has been not running new rings hard after putting crosshatching in the cylinder with a dingle ball hone. If you just idle it, the rings will wear abnormally.
9:12 AM
You should throw that hone away. Seriously.
trooney
Admitted Woodaholic
10:12 AM
The land of pleasant living
Well, I pulled that jug off. The ring gap does look a LITTLE large but I'm going to try it with the jug Steve sent me. Gotta get another gasket. You had alot of fuel in the cylinder, and the fuel line is new. I changed out an 87 for a 120 that I just rebuilt. I'll pressure test that carb. I'm going to get that fukker running, the only question is when. I still think it is the cylinder for some reason...might be the ring gap. I can always throw another ring on it...
trooney
Admitted Woodaholic
10:12 AM
The problem is getting it running, and it wasn't flooded, just gas from trying to get it started. I'll try the oil method and hopefully get it started to where I can continually run it. Didn't know cylinders could warp but they are metal...
9:12 AM
Heck, even carburetors can warp after a time.
trooney
Admitted Woodaholic
10:12 AM
Check that you didn’t shear the flywheel key. Quite easy on the model. When mine sheared, I had a saw that was doing all sorts of strange stuff.
Read the first post...jeesh. The flywheel key is intact. I'll be putting on the cylinder I got from Steve. Something is wrong with the setup..
Outback
7:12 AM
Well you have quite the murder mystery here. I go back to something randy said. Any chance there's any blockage/leak to the impulse. Badly cut gasket or damaged gasket? Tried removing the wire for the kill switch from the coil?
trooney
Admitted Woodaholic
10:12 AM
The kill switch is working. Passes a p&v test. I think it has to do with the compression/cylinder. I'll find out once I put on Steve's cylinder.
Outback
7:12 AM
Just suggesting you eliminate any possibility of unintended grounding. Good luck.
Sloughfoot
7:12 AM
Norcal
It'd be interesting to know how far off from Oem port locations are on the AM cylinder.
trooney
Admitted Woodaholic
10:12 AM
It's not an AM cylinder, it's a KS. First time I've ever had this problem to this extent. I'm hoping it's the ring or cylinder. The only thing is the gouge above the exhaust port roof. Maybe that's making it so low on compression that it won't fire. I don't subscribe to the theory that 100 psi is enough to fire off a chainsaw. But that's just me
