r7000
on a km90r trimmer, run with stihl gray bottle 2-stroke oil for its life of 5-10 years. Basic home lawn use. At worst maybe the oil mix was done incorrectly, unknowingly, over the years. Trimmer acted up this year, would not get full throttle and when feathering throttle could get it to near full rpm but would not sustain that rpm and have power. Did everything on it including crank seals and resealing the case. Would start right up and only idle nice.
Decided to keep it and got a new cylinder with piston/ring. Shop even took a look at it, after everything had already been replaced, said cylinder/ring was shot. So, ok. My question is, since I have everything apart and have a brand new unused cylinder + piston & ring in hand how can one determine wear? In the cylinder given its small and deep you're looking at it from a 10-20° angle, the new one inside looks nearly the same I don't see any crosshatch like on a 350 sbc. I do see some wear lines in the old cylinder but nothing that stands out. I guess the new piston ring looks better than the old one. The old piston was clean and shiny just like the new piston.
I'll post pics tonight.
