Cerberus
Cerberus the aardvark, not the hell-hound!!
- 2:07 PM
- Jan 20, 2020
- Florida (tampa area)
tl-dr: If you were dumb enough to not notice your clutch-cover was so packed that it was forcibly pushing debris/pulp into the clutch-drum, and this caused enough heat/friction to cause the clutch to pop a spring and make it so the machine was run, at low power but was run, in a condition wherein the chain was truly 'mated' to the engine, throwing the chain break would stall it out (because the clutch was perma-engaged while its spring was broke!!)
I have replacement parts coming, and am taking the opportunity to "patch some holes" on this new unit while it's on the bench, but wanna ensure I'm not missing some damages incurred from my errors here, and "rebuilding on faulty foundations" yknow! I checked the clutch-drum for true-ness with digital calipers, it was remarkably true... didn't really know what to check besides that, it "ran great" after the break (thankfully not for long at all, and not at full power or close-to) but was run in this condition where the clutch//engine//chain are all together, throwing the chain-brake - which I did - would stall the engine in this state! But it ran and felt normal when I was ~1/3rd revving in light Ficus wood while testing (before I discovered it I spent ~10min fiddling w/ it thinking it was the carb because this is a saw with a carb that won't return to true idle-RPM, chain spins unless you have the brake on, so I figured it was that, not the clutch, until a lil diagnosis)
Thanks a ton, don't wanna build further on it til I know whether just rebuilding the clutch is sufficient, the oiler gears and all behind the clutch look OK but I don't know what to look for :/
