corvairbob
Active OPE Member
- 11:35 PM
- Apr 9, 2025
- muskegon mi.
ok outside of getting hammered because i got a poulan pro chainsaw i have a question on starting it. it does start and seems to run out good and will set and idle good but when cold it pulls the rope out of my hands when i pull the start rope. i did it cold and then 3 primer pumps and so on until it finally started. the guy i got it from did the same thing he said it is a hard to start cold start but he did not tell me it pulls hard when cold starting. after it runs for a bit it pulls a lot easier. i still have to primer it 2 times but it pulls way easier. i can almost hold it with one hand and crank it when it is warm.
i had gas saws years ago and i could hold every one and pull start them but i did not use them enough and the carbs always got mucked up so i went to an electric saw.
i can't use that electric saw now as my house burned and i have no power to anything, they cut the lines at the pole. and i need the saw so i can cut the deck down and some trees so the builder can bring in a modular home.
anyway is this a normal thing now with these poulan pro type saws or maybe any newer saw? and i just have to get use to it? or might i be doing something wrong or maybe this saw may have a mechanical issue that i have to look into.
