hyundai generator will not start
RockySawz11
OPE Member
6:58 PM
alberta canada
first post here guys so bare with me a bit.
i have a hyundai generator ... model # hhd 7520.
it is getting plenty of fuel to the carb ... i pull the plug and it is soaked with fuel.
it has spark to the plug ... i have visual confirmation of good strong spark.
it has good compression and the key on the flywheel does not seem to be sheered ... meaning the key stock and the key way are in line as best as i can tell. i have not pulled the flywheel.
when i try to start the generator it will crank until the battery dies ... no start.
it will backfire through the carb ... and through the exhaust.
the carb is non-adjustable ... the float is non-adjustable as far as i can tell.
anyone got any ideas?
thanks, shane
7:58 PM
Welcome to the OPE.
@Onan18 might have some insight on these.
AVB
7:58 PM
Pluto
Try a know a known good plug. Just because it sparks outside the engine doesn't mean it will spark (arc) under compression/fuel load.
RockySawz11
OPE Member
6:58 PM
alberta canada
have tried 3 total plugs ... strong spark outside of engine ... it must be sparking inside as the generator is backfiring through the carb and through the exhaust.
when i pull any of the plugs ... they all come out soaking wet with fuel
it is possible there could be something wrong in the valves? ... what would be proper procedure to check and see ... what would i be looking for under the valve cover?
AVB
7:58 PM
Pluto
Since the plugs are wet and you seems to think you got good compression shut the fuel supply off so the engine get no fuel and see if it is a flooded condition. After with no going in if it is flood should at least a few revs.
With compression I no longer just guess at what it isbut use a compression gauge to see what it is but just me probably If low then do a leak down test to determine where the problem lays in the cylinder.
RockySawz11
OPE Member
6:58 PM
alberta canada
thank you friend ... it'll be monday before i get back at it ... i can borrow a compression tester, so what pressure should i be looking for ?
AVB
7:58 PM
Pluto
You should be getting around 65-70 PSI minimum. It would be high but many engines have an automatic compression release to make starting easier.
