HELP! Husqvarna duckbill valve info needed
Mike C.
11:26 PM
New Hampshire
Hi gentleman,
I was wondering if anyone would have access to Husqvarna duckbill valve part no. 530026119 . I believe I can use this part to repair a tool I have that uses such a valve,but can't find the dimensions of it anywhere on line.This is used in many models of Husky saws like the 372xp,for a tank vent.
I need the diameter of the rim,the diameter of the area where it steps down in front of the rim,and the overall length.Some fairly precise measurements taken with a caliper would be great.
Thanks,Mike C.
Woodwackr
9:26 PM
ID
Hi gentleman,
Thanks,Mike C.
I have 3 here.
One from a ms170 fuel tank which is the same as the husqvarna according to one supplier
Next is from an Echo 355t but is found in several Echo saws as well as Shindaiwas.
The larger is a mysteryHusky valve :p
Mike C.
11:26 PM
New Hampshire
The measurements you're showing in your last photo for the Stihl/Echo( which is the same part as in my photo),exactly match the size of the valve I need.I measured the associated parts in the tool to come up with those dimensions(5x4x10mm).So all I have to do is order part Husky 530026119 and I'm back in business.
Very much appreciate your time and effort,Woodwackr.Cheers.
Woodwackr
9:26 PM
ID
Echo/Shindaiwa will be your best bet, and cheaper. Any echo dealer can get them. Locally, Echo is a 4 day wait. Husqvarna is 2 months.
Oops…you need the Stihl part, duh…one moment
0747 313 6810
Stihl pt#
Usually a week for me.
Mike C.
11:26 PM
New Hampshire
The Echo unit you show won't work for my application,it has to be shaped like the Husqvarna part.There's a spring that fits around the outside.
Thanks again for your help.Mike C.
Woodwackr
9:26 PM
ID
Edited :p
Agrarian
11:26 PM
New Hampshire
I have 3 here.
The larger mystery one may be the duckbill from the Husky 2100 manual oiler (501 56 65-01).
