husqvarna 61 conversion 272xp problem
cblendz
New OPE Member
12:16 AM
ct
I have an old husky 61 white top and i recently did the 272xp conversion but am having problems with the idle.
I swapped cylinder, piston, decompression, caburator, air filter, and muffler to 272xp. It starts and idles, the low is dialed in, but when i hit the throttle to cut it dies out. I can't tell if it is bogging or starving for fuel, if I hit throttle a few times RPMs drop and then will come back up or die.
Any idea what the problem is? Thanks!
12:16 AM
When it dies, do you have to choke it to get it started again? If so, it's a lean bog, and your L or H screw need to be turned out.
If it smokes when it stalls, your H screw needs turned in or the inlet needle lever is set too high.
Or maybe the carb needs rebuilt, or a new spark plug. Take some pics or a video and post it up. We'll help if we can
12:16 AM
@Mastermind, could you move this to the chainsaw section to get the OP some more help?
Chainsaw Jim
Con Artist LLC
9:16 PM
Springfield Oregon
The importance of the correct intake block is a good point.
You also need to trust the kit in the carb is fresh when rebuilding anything.
