slackinoff
- 11:34 PM
- Nov 24, 2021
- usa
This build is for a good friend of mine. Not completely sure on the cylinder just yet, but it's going to be a 272. I have all the other parts ready.
If you are interested in checking out a direct comparison of a 272 Hyway Titanikel p&c and a 272 OEM cylinder p&c, check out my other thread - https://opeforum.com/threads/oem-272-cylinder-compared-with-hyway-titanikel-272.26503/
Tillotson 224a carb from a 266 (same venturi diameter as the 272 carb, but it's set up for the older style saws that have the idle screw in the case)
Carb rebuild kit and new throttle plate
OEM intake block, gaskets and screws
OEM air filter & horn
Oregon rim sprocket (later style)
Nachi bearings and new crank seals
Orings for the oil pump outlet and crank seal holders (let me know if anyone needs these, I have a bunch)
Top cover
Replacement trigger
I'm adding pics in a few min.
Top cover
Replacement trigger
