STIHL Husqvarna 44 piston and cylinder kit
MACHINE
10:28 PM
Broken Bow, Oklahoma
Anyone have a part number or where to order from????
Sent from my SM-G930F using Tapatalk
msellers
7:28 PM
Nevada
Husqvarna 44 p&c are NLA, best bet is eBay or find a parts saw. The 346 oe piston can be made to fit, but have only read about that one. Unless someone here will part with some of their parts.
Mike
MACHINE
10:28 PM
Mike
I was afraid of that, saw is in great shape , just scored cylinder
Ty
msellers
7:28 PM
Nevada
You can put the 444 cylinder on the 44 as an upgrade, bjt is NLA also. Am sure there are a few other options for a frankensaw kinda build, but haven't heard anything about the 44 being built that way.
msellers
7:28 PM
Nevada
Ty
Is it possible to clean it up some and maybe just swap a piston?
MACHINE
10:28 PM
Did , cleaned up fine , starts and runs , but runs out of fuel on top end , going in carb Sunday
msellers
7:28 PM
Nevada
Awesome, shouldn't be long till you have a great little saw. Lots of firewood has been cut with them over the years.
Where did you source you piston if I may ask?
Mike
MACHINE
10:28 PM
Mike
Cleaned that one up , it looked like hell , but was not damaged bad at all
msellers
7:28 PM
Nevada
Nice, wish the pistons I needed to replace were saveable. At least the cylinders have been for the most part.
MACHINE
10:28 PM
The ring was barely stuck , came right out , cleaned groove , 1st test was 122, ran it a bit today, a lot more compression, going to psi test it Sunday,
MACHINE
10:28 PM
Little saw looks good, get this idle problem fixed it will be nice
MACHINE
10:28 PM
P and V test revealed a ad chain side seal , got to find one and the 44 will be done
Farmchuck
10:28 PM
Nepa
Nice looking 44. Looks older than mine. Mine has the gray cover, think I bought new around 1984/85
MACHINE
10:28 PM
Saw had fire , now has no fire ...
Crap....
It had fire before, I will check it later
