STIHL Husqvarna 44 piston and cylinder kit
MACHINE
9:32 AM
Broken Bow, Oklahoma
Anyone have a part number or where to order from????
Sent from my SM-G930F using Tapatalk
msellers
6:32 AM
Nevada
Husqvarna 44 p&c are NLA, best bet is eBay or find a parts saw. The 346 oe piston can be made to fit, but have only read about that one. Unless someone here will part with some of their parts.
Mike
MACHINE
9:32 AM
Mike
I was afraid of that, saw is in great shape , just scored cylinder
Ty
msellers
6:32 AM
Nevada
You can put the 444 cylinder on the 44 as an upgrade, bjt is NLA also. Am sure there are a few other options for a frankensaw kinda build, but haven't heard anything about the 44 being built that way.
msellers
6:32 AM
Nevada
Ty
Is it possible to clean it up some and maybe just swap a piston?
MACHINE
9:32 AM
Did , cleaned up fine , starts and runs , but runs out of fuel on top end , going in carb Sunday
msellers
6:32 AM
Nevada
Awesome, shouldn't be long till you have a great little saw. Lots of firewood has been cut with them over the years.
Where did you source you piston if I may ask?
Mike
MACHINE
9:32 AM
Mike
Cleaned that one up , it looked like hell , but was not damaged bad at all
msellers
6:32 AM
Nevada
Nice, wish the pistons I needed to replace were saveable. At least the cylinders have been for the most part.
MACHINE
9:32 AM
The ring was barely stuck , came right out , cleaned groove , 1st test was 122, ran it a bit today, a lot more compression, going to psi test it Sunday,
MACHINE
9:32 AM
Little saw looks good, get this idle problem fixed it will be nice
MACHINE
9:32 AM
P and V test revealed a ad chain side seal , got to find one and the 44 will be done
Farmchuck
9:32 AM
Nepa
Nice looking 44. Looks older than mine. Mine has the gray cover, think I bought new around 1984/85
MACHINE
9:32 AM
Saw had fire , now has no fire ...
Crap....
It had fire before, I will check it later
