- 10:22 PM
- Jan 26, 2016
- South west UK
Any saw can be used for milling. What you are content with is another matter depending on size, specie's, volume and speed of cut desired.
Keep it towards the fat side of tuning and run a 32:1 ratio for survivability purposes of the bottom end which imo can be the weakest point of this particular model depending on usage.
Thanks i was also thinking about a farmertec h288 or the 395 versionWhat Stump Shot said.
I milled my first log with an ms290. It was on the smaller side. When I had the opportunity to mill bigger stuff, I built a pair of clone 660s. At some point, when I’m tired of messing with them, I’ll buy a proper milling saw or saws.
I'd definitely choose OE over chinese rip off any day. I like the outboard clutch for keeping some of the heat out of the case/pto bearing but that 390 will do fine. Run it rich and tune it fat...Thanks i was also thinking about a farmertec h288 or the 395 version
Got chance of a nice husky 390 wondered what there like for milling need a saw for
some wood maximum width 20” so not over big
here’s the saw
View attachment 384145View attachment 384146
It should do just fine. I milled a few hundred board feet of white oak, black walnut, honey locust which is as hard as your mother-in-law's head, sugar maple, & red pine with a 920 Jonsered (88 cc). What Stump Shot said plus use a ripping chain. I was using a 34in bar & producing boards as wide as 24in. Use the best available air filter like Red Beard or West Coast Saw foam. Ripping makes LOTS of dust rather than chips!Got chance of a nice husky 390 wondered what there like for milling need a saw for
here’s the saw
Until I got a bandsaw mill, I regularly used a 390 for milling without issue. Mainly milling large spruce. In addition to Stump Shot recommendation I would also add make sure you keep the chain sharp. Every time you fill up, run the file over the chain. You'll say time and decrease the wear and tear on the saw and chain.
Yes i hadn’t thought about a decent air filter like the one you mentionedIt should do just fine. I milled a few hundred board feet of white oak, black walnut, honey locust which is as hard as your mother-in-law's head, sugar maple, & red pine with a 920 Jonsered (88 cc). What Stump Shot said plus use a ripping chain. I was using a 34in bar & producing boards as wide as 24in. Use the best available air filter like Red Beard or West Coast Saw foam. Ripping makes LOTS of dust rather than chips!
those boards look lovely , chain is the next one theres several options out There 404 3/8I’ve never used a specific milling chain, just adjusted angles on the full chisel loops I had. Works fine, full skip or full comp.
I will think twice before agreeing to mill honey locust again. After a couple cuts, it took over a tank to make one cut.
Walnut mills pretty easy.
Planning on milling with my Jonsered 2188. Where would I get a better air filter for that?
Yes, I have a 42" that came 3/8, it's an Oregon. And if you want to go beyond:those boards look lovely , chain is the next one theres several options out There 404 3/8
and 3/8 lo pro which could be a problem for big torquey saws I’ve got a 42” 404
and a 46” 3/8 lo pro but no 3/8 bars over 32”
is there a 3/8 bar D009 mount longer than 32”
https://www.newenglandsaws.com/product-page/50-gb-titanium-bar-and-ripping-chain-husqvarna-mount-1
