- 2:52 PM
- Jan 17, 2016
- Wv
Done yet?
Done yet?
Great thread, just what I was looking for! I have at least 5 372’s with bad cranks, so now I’ll split my first case.
Thanks for the heads up on the crank kits. I’ll order a few and see how they work as I’ve had good luck with Farmer Tec.HLS has FarmerTec crank kits on sale with bearings, seals, and gaskets if you wanna go that route. Cheap way to get one up and running. Lotta guys are runnin' those complete kits with decent results. The crank can't be much worse than OE on one o' those.
https://www.hlsproparts.com/ProductDetails.asp?ProductCode=H35365-DNS
Me too haven't lost a china crank yet.Thanks for the heads up on the crank kits. I’ll order a few and see how they work as I’ve had good luck with Farmer Tec.
they do have something built in for starting, ive seen em where they tend to “surge” at idle, and my understanding is thats the coil coming in and out of the advance/tard. maybe ur idle setting is right on the edge...372xp xtorq problem - normally I take most of these and make xp's out of them but the cylinder was in nice shape so rebuilt it as as is, was a 365 but changed the plates on the sides of the cylinder , now it runs good except for one thing, after you come out of the cut the idle is too low and eventually will go back to normal after a bit, - don't think it's the carb, could it be the blue coil acting up, almost sounds like a timing thing, like you retarded the timing for about 30 seconds or less??? Just wondering if this is a starting thing built into the coil but it's brains are scrambled?
Was messing with that and just get it right the way I normally set up carbs, does its thing nicely not under load , cuts nice then it does its low thing and the returns to a proper Idle... have a near new carb, I will try that and also change coils . had another 372 xp not wanting to idle to a low speed area or it would just shut off... changed coils and worked like it should. Spark plug looks like a normal color... let ya know what happens.... might leave it alone today or it might become one of my slightly modified XP'S
