Husqvarna 350 wont run
oologahan
5:24 AM
Oologah, Oklahoma
I can get it to start for a few seconds, but it dies right after that, only starts and runs for a few seconds on choke or half choke, when I push the choke off, it dies. If I leave it running with the choke on it dies in a few seconds as well. I have a factory rebuilt carb on it and all the fuel lines check out ok. There is a brass perforated collar that goes into the rubber boot and it actually ran a little longer when I forgot to put it in. I found no cracks in the intake boot, but it was really hard to tell with the boot on, could it be the boot or maybe crank seals Thanks
EFSM
5:24 AM
Extreme southern IL
Use a can of carb cleaner or ether with a straw preferably and spray around the crank seals, base gasket, and intake boot. If it runs longer or dies as soon as you spray at a certain place, good chance you've got a leak there.
oologahan
5:24 AM
Oologah, Oklahoma
Thank you, that helps a bunch
oologahan
5:24 AM
Oologah, Oklahoma
Would you know how to remove the partition and intake boot, I've tried but I don't want to break the parts taking them off
Coupe
11:24 PM
New Zealand
Sounds like a blocked carby. Take it to bits and give it a good clean spray plenty of carb cleaner in it
and if you have a set of carby cleaners give it a clean with them. Be careful if you use them though don,t
break one off in a jet.
I have had saws do that and by giving them full choke thay will run and the reason why is the sucking every bit of gas they
can through the carb. Soon as you push the choke to off can,t get petrol.
oologahan
5:24 AM
Oologah, Oklahoma
Its an OEM rebuilt carb, leak down tests fine, plenty of fuel getting to the carb, it has a massive air leak at the bottom of the intake boot
hacskaroly
2100 Fanclub Member
3:24 AM
Northern Idaho, Ehh
Here is a video of a 350 tear-down, might give you an idea what you need to do to get to the intake boot.
Like @Woodslasher stated you most likely will need to take the cylinder off. I have worked on a couple of Husky saws and it is much easier to have the cylinder off to attach the intake boot or block than it is trying to monkey it on or off with the cylinder still on the saw.
This gives you an opportunity to give that area a good cleaning and inspect the cylinder and piston for unusual wear marks.
oologahan
5:24 AM
Oologah, Oklahoma
Thanks a bunch, that makes perfect sense. I went ahead and loosened all the screws on the cylinder and will blow it off and clean it before completely pulling the cylinder. I looks like the intake boot might have come loose at the bottom. I see the cylinder gasket is broken and I'll pick up one of those along with the rest of the intake parts. BTW, is there ANY gasket between the carb and the boot?
hacskaroly
2100 Fanclub Member
3:24 AM
Northern Idaho, Ehh
Here is what the IPL is showing for parts in this section:
The entire IPL can be found at this link: Husqvarna 340/345/360 IPL
Edit: I reread what you wrote and highlighed the wrong area. It appears the carb matches up to part 537 42 21-01 with the ring 537 02 90-01 in between. I imagine the ring fits through 537 42 21-01 and fits in the boot 503 86 63-01. But no standard gasket to speak of.
Woodslasher
Teh debil
3:24 AM
Commiefornia
Nope, the rubber boot seals against the aluminum carb body, no gasket required.
oologahan
5:24 AM
Oologah, Oklahoma
I got it running, bad boot, but biggest issue was the carb, I bought a new rebuilt carb and still wouldnt run, had an air leak. I dunked the carb in water and put pressure to it. The plastic fuel barb was cracked, after replacing the boot and fuel barb the saw ran great. Thanks everyone, still not a fan of newer huskys
