Husqvarna 346xp tuning issues
Turner Saw
11:01 AM
Ohio
I recently picked up a couple 346xp's to rebuild. I did complete rebuilds on both saws. New crank bearings and seals all new gaskets OEM NE piston and cylinder kits. Now that I have them running I'm having the same problem with both of them. They run so rich i can't get them to stop fouling plugs. They won't rev and just burble at wide open throttle. Raw fuel in the exhaust. I've tried ignitions and carburetors from perfectly running saws with no luck. Everything is sealed up good. Never had this problem before. Any ideas?
Turner Saw
11:01 AM
Ohio
I had one that I rebuilt and everything looked perfectly fine but it acted exactly like that, until i swapped the air filter. Looking at it you couldn't tell it was the mesh type.
I read your reply and went out and pulled both filters. Both saws are screaming and cutting like crazy! I would have never guessed that one. Thank you!!
cuinrearview
Handy dood
11:01 AM
Dowling, MI
Did they run it so long like that that this happened?20190717_074117.jpg 20190717_062712.jpg
If you still have the original cylinders and want to part with them shoot me a PM.
