Husqvarna 3120xp ported inconsistent 4stroke rpm
davidwyby
Rural desert logging
6:46 AM
Extreme Southeast CA
Fuel line feels ever so slightly softer than the new echo line in my 395. The filter looked ok but I changed it.
Would someone elaborate on the oil lube port in the crank and fill me in?
redline4
I'm huge in Japan
8:46 AM
Rosholt Wisconsin
Look at the clutch side end of the crank.
It will have an open hole in the end.
jacob j.
Only the weird
6:46 AM
Coastal Oregon
Yeah most saws do I think…but what is the problem with it and why are we plugging it?
I think the theory was that excess oil from the crankcase would travel down the opening (in the center of the PTO side crank throw) and then come
out that opening where the clutch drum bearing is to keep that lubed. However, a lot of the time it presents an air leak in the chainsaws.
I know on three 3120s I've built, I've had to plug it.
redline4
I'm huge in Japan
8:46 AM
Rosholt Wisconsin
Not on the end of the 3120 Ed. It comes out off the center of the crankshaft inside the case, and ends at the clutch drum bearing.
Ahhh, OK.
Thanks for the clarification and yeah, now that I actually think about it, how would the hollow grease end cause an air leak...
Dum chit..
qurotro
Cookie Cutter
8:46 AM
Ar
The hole on the drum bearing is a cheap out thing for Husky I think. If you have a 371K saw, that crank has this type of hole to the crank case but no hole on chainsaw cranks. They just made 3120 chainsaws using 3120K's cranks.
I have a 371K converted to chainsaw with that hole in the crank, it run just fine as a chainsaw.
davidwyby
6:46 AM
Hole in clutch bearing area goes to outside for greasing, not to inside of case.
  • Like
Reactions: Lnk
9:46 AM
How’s the tank vent? Air filter?
Sounds fuel related. I personally can’t see how a small air leak through a poorly engineered crankshaft weep hole would cause a high rpm issue. Should be able to tune it out. With a wide open throttle blade a tiny air leak shouldn’t pose a problem. A massive one that pulls a rip open in a boot or seal would, but there is less vacuum in the case when the butterfly is wide open.
Could also be a heat thing changing tune. Seems to hold same rpm for a few seconds and then jump. Most ported saws will jump in rpm when hot, part of why I like AT saws.
If you fatten it up more, will it hold the lower rpm steadily?
davidwyby
6:46 AM
I idled it and gave it the spray leak test today. Didn’t find any leaks or loose bolts. I didn’t fool with the H as the saw is godawful loud and I don’t want my neighbors to hate me. Also, Need to put clutch bar and chain on and put it in wood to test/tune properly warmed up.
